Adhesion Problems
Ask an Expert From: Products Finishing, from Powder Coating Consultants, Div. of Ninan, Inc.
Posted on: 7/1/2003
Question: We are a custom coater and have a potential job should we be able to overcome adhesions problems.
We are a custom coater and have a potential job should we be able to overcome adhesions problems. The part is an exterior part made from cast steel. It does have machined surfaces (initial adhesion test looked good on the cast surface and poor on the machined surfaces; however in the end, adhesion was poor on both). This part is zinc plated. We have run tests on plated parts with the zinc/chromate, and we have run tests on zinc plating with a brightener dip. Prior to both tests, we pre-baked the parts at 450F for at least a half hour. The geometry of the part is a 12-inch OD, nine-inch ID, and average thickness of one inch. The weight is approximately 15 lb. With the zinc chromated parts, the coating just flaked off with a crosshatch. In the impact test, the parts looked good, initially. On the zinc only with the bright dip, parts all looked good after the impact test but, in the cross hatch all peeled off. These parts did have a black soot powder between the coating and substrate (in both tests the parts went through a baking only and did not run through the three stage wash, for two reasons: 1) fear of taking on moisture; and 2) parts should be clean due to the plating process). So, what’s up with this? Why won’t it stick?  Please advise. Thank you. M.G.
As I always tell my clients: “Nothing good happens to a part once it has been cleaned, so coat it right away.” That is my advice to you. Even though this part was cleaned during the plating process, the surface can be contaminated as it sits around waiting to be powder coated. Also, the plating process can leave salts on the surface, so be sure to use DI or RO water as a final rinse.
If cleaning the part right before powder coating does not correct the problem, look at your cure cycle in the oven. The part you describe is quite massive and can be under-cured in your oven. Run an oven profile using an actual part to determine the correct dwell time and oven temperature. Under-cured powder coatings will often show poor adhesion test results.
Learn More
Zones
SIDSP
Therma-Tron-X
Magic Rack
The Voice of the Finishing Industry Since 1936 Copyright © Gardner Business Media, Inc. 2016
