Butler Finish Nickel
Question: What is “butler finish nickel?” How does one apply this finish?
What is “butler finish nickel?” How does one apply this finish? R.J.
This question was asked by another reader a number of years ago. Here is the response I gave at that time. The butler finish nickel is a fine satin finish. This finish originally resulted from the regular cleaning and polishing of fine silverware. One way to produce the finish is to wet scratch the surface with a suitable wire brush. An easier way is to buff the surface using fine grit, greaseless buffing compound. The type of nickel bath is important. Bright nickel baths give a finish that is too glossy so a dull or semi-bright bath should be used.
Since you have not used this process before I suspect you will have to do some experimentation with the conditions in order to get the most satisfactory results.
RELATED CONTENT
Stripping of Plated Finishes
The processes, chemicals and equipment, plus control and troubleshooting.
Zinc Electroplating
