Five-Axis Machine for Continuous Milling
New Product From: Modern Machine Shop
Posted on: 4/26/2013
GF AgieCharmilles’ five-axis HEM 500U features a dynamic 12,000-rpm spindle and 30-tool magazine providing a chip-to-chip time of 2 sec.
CLICK IMAGE TO ENLARGE (+)
GF AgieCharmilles’ five-axis HEM 500U features a dynamic 12,000-rpm spindle and 30-tool magazine providing a chip-to-chip time of 2 sec. for high-speed continuous milling operations. A 20,000-rpm spindle and 60-tool changer also are available. The machine is said to be well-suited for machining aluminum, alloy and steel parts.
The 19.7"- (500-mm-) diameter trunnion table accommodates workpieces weighing as much as 44 lbs (200 kg). The table tills +50/-110 mm in the B axis and rotates 360 degrees in C for 3+2 machining as well as five-side positioning. X-, Y- and Z-axis travels measure 19.7" × 17.7" × 15.7" (500 × 450 × 400 mm). A distance of 5.9" (150 mm) between the machine spindle nose and rotary table surface enables greater maneuverability around workpieces. A Heidenhain iTNC 530 control for five- (3+2) axis machining features an integrated digital drive control with inverter designed to produce a highly accurate workpiece contour while machining at high velocity.
GF AgieCharmilles also will showcase its Cut 200 wire EDM and Form 20 sinker EDM.
Learn More
Related Suppliers
The Voice of the Finishing Industry Since 1936 Copyright © Gardner Business Media, Inc. 2014
