Multi-Color Finishes
Question: Way, way back, about 30+ years, I remember that there was a coating that when sprayed resulted in a “multicolor” spatter finish.
Way, way back, about 30+ years, I remember that there was a coating that when sprayed resulted in a “multicolor” spatter finish. At that time, I inquired how that finish produced two colors at one time when sprayed. I found out that the material consisted of two incompatible coatings, probably one a lacquer and one a latex material. It has been quite a while since I have tried to recall the blend. (I don’t think that the second material was an alkyd since I suspect that the two would blend.) These two remained separated when atomized. At this moment I can’t think of the trade name used. Do you remember what it was called and what the blend was? I wonder if this coating is still made? Thank you for a wonderful, informative column.
In 1960, I had a program at the Westinghouse Labs to evaluate Plextone finishes, a registered trademark of Maas and Waldstein. Plextone is one of the novelty finishes mentioned in the February 2003 Painting Clinic. It consisted of a suspension of colored nitrocellulose lacquer droplets in a water-soluble resin base. The water-soluble resin was the continuous phase; nitrocellulose was the discontinuous phase. The water-soluble resin could have been an alkyd. Numerous effects could be achieved by varying the base color and the color of the droplets.
Featured Content
Since the finish provided optical interference, it was proposed for use on fabricated sheet metal structures. It offered potential savings by eliminating labor intensive grinding, sanding and filling operations used to correct surface defects. It was found to be equal in performance properties to the then existing finish. In the end, the engineering “committee” rejected its use because it looked too much like baby furniture. Incidentally, our first set of baby furniture (bought by my mother-in-law in 1956) had a Plextone finish. No wonder my son became a lawyer.
Follow Up:
We have manufactured multi-color coatings since 1952. The coatings you eluded to, nitrocellulose lacquer-base multi-colors, are still manufactured for OEM applications. Multi-color coatings have advanced considerably since that time. The latest technologies are water-in-water multi-color. These technologies are VOC compliant in all markets, including California. We manufacture a wide variety of multi-color coatings for many different uses. The primary market segments are architectural, focusing on office complexes, health care, hospitality, education and retail stores. We also continue to manufacture coatings for the OEM market as well as getting into the retail market with roller applied multi-color.
My investigation of multi-color finishes took place in 1959. I failed to mention above how we found out about them in the first place. When my son was born in 1956, I bought him nursery furniture, a crib and dresser, finished with multi-color paint. Having been in the paint business, I appreciated novel finishes. It seemed to be a perfect fit for our industrial application to hide surface defects. I liked it and the Marketing Department liked it, but we couldn’t sell the idea to the Engineering Department.
The company name was withheld because I don’t mention company names in the Painting Clinic, but I will supply it to interested parties by e-mail.
RELATED CONTENT
A Current Affair: Examining the "No Amperage" Phenomenon
If you are performing a coating process that requires the use of a rectifier, you may have experienced the "no amperage" problem. Here's a look at the phenomenon and some solutions…
Curing Oven Basics
