Paint Bleed Through
Our company has manufactured industrial solvent-based and water-based coatings for the drum reconditioning market for many years. I interpret the question from the December issue (www.pfonline.com/articles/clinics/1206cl_paint5.html) to be a problem with the overspray bleeding through at the time of application.
Related Topics:
Q. Our company has manufactured industrial solvent-based and water-based coatings for the drum reconditioning market for many years.
I interpret the question from the December issue (www.pfonline.com/articles/clinics/1206cl_paint5.html) to be a problem with the overspray bleeding through at the time of application. The upper and lower panels are usually applied at the same time, with the middle stripe being applied immediately thereafter (or visa versa). This is a very common problem and solved by adding a flow agent (surfactant) to the first coat so the second coat will flow over and absorb the overspray. Let me know if we can be of any further help. C. T.
A. Thank you for writing to Painting Clinic and thank you for your comments. Our interpretations of S. J.’s problem differ. The condition he describes as “...pigments floating thru each other...” are caused by a full coat of paint applied over another uncured full coat of paint. Over spray, which comes from the edge of the spray pattern and is not intended to paint the product, would be dryer and the it would manifest itself as discrete particles resulting in a rough finish, similar to a texture finish.
In S. J.’s case, I believe the solvents in the second coat are dissolving the first coat of paint. To solve this problem, the first coat must be cured before applying the second coat. One of the important properties or stages of a curing paint film is “time to recoat” which is listed in the paint’s product data sheet. I know he will hate to hear it, but a heat pump between coats may solve his problem. And yes I know, heat bumps cost money.
Pocket Tester Measures Water Quality
EcoTestr pocket testers, available from Gardco, feature updates designed to quickly and easily measure water quality.
