Paint Over Powder Coating
Can I paint over powder coating? Will the paint adhere?
Related Topics:
Q. Can I paint over powder coating? Will the paint adhere? One of our customers supplies coated aluminum castings to a small appliance manufacturer. He has a number of aluminum housings painted with a white polyester powder coating. Now the manufacturer wants castings in other colors. G.W
A. Paints will adhere to powder coatings, providing there is no slip agent present on the surface. Slip agents are often formulated into powder coatings to increase their mar resistance. Your customer’s powder supplier will tell you whether a slip agent is used in his powder. If the slip agent is present on the powder coating’s surface, it must be removed before painting by solvent wiping or sanding. If this procedure does not remove the slip agent, the castings must be stripped to bare metal.
After the appliance castings are prepared for recoating, I suggest using a polyester, thermosetting acrylic or polyurethane enamel to achieve the same high quality.
Pocket Tester Measures Water Quality
EcoTestr pocket testers, available from Gardco, feature updates designed to quickly and easily measure water quality.
