Streamline Your Mold Cleaning Process
Article From: MoldMaking Technology, Frank Pedeflous
Posted on: 9/1/2006
Ultrasonics can help your shop reduce labor costs and product waste while boosting efficiency and product quality.
CLICK IMAGE TO ENLARGE (+)
Molds cleaned with ultrasonics
Molds cleaned with ultrasonics require less start-up, produce less waste, require less troubleshooting and maximize the mold’s run time. Before cleaning (left) and after cleaning (right).
After cleaning
After cleaning, molds are placed into stock ready for their next production run.
Disassembles most molds
Kaysun disassembles most molds before placing them into the washer.
Labor intensive hand scrubbing
Most injection molders still clean with labor intensive hand scrubbing and solvents. Images courtesy of Omegasonics.
Plastic injection molding offers many benefits to the buying public. Lightweight, durable plastics de-signed to enhance the American way of life. Injection molders benefit from a more diverse array of products they can sell and the profits generated by those sales. The challenges for the plastic injection molders are keeping up with demand, discovering advanced techniques to expand their manufacturing base and keeping their molds clean and in good working order.
Most injection molds are still cleaned the old fashioned way with labor-intensive hand scrubbing and solvents. Though nostalgia is great for many things, cleaning molds should not be one of them. Molds become contaminated with grease, hydraulic oil, rust, grime, carbon, aluminum shavings and material gassing. Gordon Schwartz, Program Manager of Kaysun Corporation in Manitowoc, WI, received a challenging project: find a better way to clean his company’s injection molds.
Shopping Around
Kaysun Corporation was established in 1947 during the early years of injection molding, bringing plastic goods into the American economy. Their first products were model airplane parts, cookware and commodity items. The business has been expanding rapidly for the past 12 years because of their willingness and desire to invest in cutting-edge technologies to solve a variety of customer needs from automotive to industrial to military markets.
Schwartz attended a lean manufacturing certification course. His central task was to streamline the mold cleaning process. After extensive research on the Internet and investigating other manufacturing companies in the area, Schwartz found his solution in ultrasonics.
At the time, Kaysun employed three technicians in the mold maintenance department. Because Kaysun’s business was expanding, they were going to bring on a fourth individual to handle the increased volume.
Schwartz brought three different manufacturers of ultrasonic equipment into their facility to evaluate their equipment and service. After some testing Schwartz determined that Kaysun could avoid hiring that fourth technician for the price of a $16,000.00 ultrasonic parts washer.
While all three ultrasonic machines tested out well, Kaysun chose a larger floor model based on its demo, its filtra-tion package, easy operator interface, exceptional price value and customer recommendations.
Integrating Ultrasonics
Wayne Hurkmans is the head of the mold maintenance department. His charter was to integrate the ultrasonic parts washer into Kaysun’s operation and find the right balance of chemistry, time and temperature.
Hurkmans chose to use a water-based, biodegradable mold release specifically designed for cleaning injection molds with burnt-on crystalline plastic residue. The soap was mixed at a 13:1 ratio with water. The bath temperature was heated to 150°F. Depending on the type of mold, the intricacy of the mold and the type and level of contamination, molds are cleaned in a hands-off ultrasonic environment between 5 and 60 minutes.
Kaysun’s maintenance department generally disassembles the mold before placing the parts into the washer. After cleaning, molds are rinsed in hot water to remove any soap or residue, then blown dry with compressed air and placed back on a machine or into stock for the next run.
Hurkmans confirmed that the time benefits have been outstanding. A mold with baked-on, carbonized hydraulic oil might take as long as three hours to clean by hand. With ultrasonics, it is only one hour. Even light to moderately contaminated molds might take 30 to 60 minutes with manual cleaning, while 10 minutes is all that is required with the ultrasonic washer.
But time is only one of the benefits ultrasonics has for plastic injection mold cleaning. Hurkmans continues, “Molds look brand new. Ultrasonics is quicker and cleans better, especially for intricate parts. Tool life is extended as well. Everything is just better with ultrasonics.”
Vents built into molds allow gas to escape during the gas-off process, but these vents become clogged with usage. Clogged vents trap gas—resulting in gas burns in the steel mold, thereby shortening the life of the mold. Ultrasonics cleans the vents more thoroughly, maximizing the stretch of time the mold can stay in the run before it must be rotated out.
Cost to Value Ratio of Ultrasonics
Kaysun has found an excellent cost to value ratio in using ultrasonics. Molds that are not properly cleaned generate waste product. As an example, out of 100 pieces, six may be out of spec and thereby rejected. Cleaner molds are easier to run and maintain. “The better the mold, the better the parts, and the longer the mold keeps parts within specification,” says Schwartz.
Molds that are extremely well cleaned with ultrasonics provide positive results throughout the production process:
  • Less start-up time
  • Less waste
  • Less labor time with reduced troubleshooting required by the mold technician
  • Less time that a line needs to be shut down
One final benefit of a properly cleaned mold is the ability for the injection molder to go after more profitable, highly-engineered projects. Because of deeper crevices and cracks, an injection molder confined to hand cleaning cannot effectively and profitably compete in this arena. They are confined to the lower profit, highly competitive projects with mainly flat surfaces.
Ultrasonics helps Kaysun Corporation stay on the cutting edge by reducing labor costs and product waste while boosting efficiency and product quality. It is a technology that adds to the company’s profitability, making it a wise investment.
Learn More
Editor's Picks
Cleaning Molds: Part I
Cleaning a mold is a critical part of the repair process, but many ...
Choosing and Using the Right Mold Cleaners
Knowing the requirements of offline and online cleaners yields clea...
Related Suppliers
Omegasonics
