Not only does SUR/FIN 2011 give attendees the opportunity to learn from and network with peers in the surface finishing industry, it does so with the beautiful city of Chicago and all it has to offer as its backdrop. This year’s conference is being held at the Donald E. Stephens Convention Center in Rosemont, Ill., a 2.5-square-mile village conveniently located between O’Hare International Airport and Chicago.
NASF has negotiated a special rate of $159 per night for conference attendees at two hotels—the Crowne Plaza Chicago (847-671-6350), located directly across the street from the convention center, and the Hyatt Regency O’Hare (847-696-1234), connected to the venue by a covered walkway.
Editor's Picks
Titan Metal Fabricators is displaying its line of titanium rectangular and round anode bas...
Process Technology, a wet process heating and cooling manufacturer, is introducing its Sma...
Newact Inc. will display its danglers, which are now produced with a CPE overmold.
Watermark will have a working 470mm Filter Press on display, complete with a treatment ski...
Company offers a broad line of patented self-cleaning filtration systems, carbon treatment...
Pavco will showcase two zinc nickel alloy technologies to help meet the growing demand for...
MacDermid’s NiKlad Eclipse, on display at Sur/Fin 2011, is a process designed to consisten...
Brenntag Mid-South Inc. will exhibit its full line of industrial and food grade chemicals ...
The GRX-70 high-speed electrolytic process from Uyemura is designed to prevent whisker for...
Sequoia Corp.'s Stop-Off Tape is designed to hold its edge in temperatures up to 210°F.
Eco-Tec’s Nickel Salt Recovery System is desigend to recover more than 95% of the nickel f...
The Dangler Quick Connect by CPP (“The Dangler Guys”) will be on display at Su...
GF Piping Systems will display its Signet Model 2552 Metal Magmeter, a rugged insertion fl...
UPA Technology will display its full line of X-ray instruments for accurate plating thickn...
Sifco Applied Surface Concepts provides brush plating sokutions for repair and resize of l...
Columbia Chemical will display SpectraMATE 151 CFT, the latest in cobalt-free, trivalent c...
Univertical is displaying its Copper Sulfate Crystal, which it says is demanded in high-en...
Clepco products will be on display in the Intelligent Heater booth at Sur/Fin 2011, includ...
Dynamix’s Dynastrip RT is an environmentally paint and powder coating stripper that will s...
Serfilco’s new, compact Mega-Flo filtration systems offer high flow rates (8,500-21,000 GP...
Finish Thompson Inc. will exhibit a new pump model in its premium DB Series line.
The display will feature products coated using the variety of systems available from Dörken.
Measurement technology company Fischer will be displaying many instruments applicable to t...
Dynapower and Rapid Power will display their efficient and reliable power conversion units...
Sethco offers a complete line of horizontal and vertical corrosion resistant pumps with ca...
Lanco Corp.’s booth will highlight a number of quality pieces of equipment from its two wa...
Metalast International will be showcasing its trivalent and no-chromium family of products...
Heatbath will display its new Triumph Plus, a highly corrosion-resistant trivalent chromat...
Met-Chem along with sister companies, Poly Products and Auto Technology will feature its f...
PPG has introduced new waterborne clearcoat technology for automotive refinish.Positioned ...
E-Brite Ultra Cu is a unique cyanide-free alkaline copper plating process with covering ...
Aluminescent is a REACH, RoHS, WEEE and ELV compliant and MIL-DTL-5541F approved conversio...
Kocour will display its compact, quick-learning thicknes tester.
Cyanide Destruct Systems will be answering inquiries regarding the benefits of its Thermal...
Enthone will display its family of PFOS-free wetting agents/fume suppressants (WAFS) ...
Goad Co., a manufacturer of process tanks and tank lining contractor, has developed an inn...
DiamonDyze, on display in the Tech Line Coatings booth at Sur/Fin 2011, is said to be a br...
Hunter Chemical is a provider of electroless grade nickel sulfate and nickel chloride solu...
Ryan Herco Flow Solution will be displaying at Sur/Fin 2011.
Haviland's Antifoam H has been successfully applied in a wide variety of processing and wa...
EPi will display its alkaline non cyanide copper and silver processes and trivalent chromates.
Innovative Heat Concepts says the PTC technology it is displaying at Sur/Fin is energy efficient.
Nihon Ruspert Co. Ltd. will be exhibiting Lafre, an innovative rustproof technology that c...
Hubbard-Hall Inc. will display a new product in its Emerald line of earth friendly, heavy ...
Midwest Air Products Co., manufacturers of PVC and polypropylene pollution control equipme...
Price Industries is providing information on its custom “turnkey” process line...
Hardwood Line's RinseMaster is designed to reduce water consumption, leave parts without d...
Met-Pro Environmental Air Solutions will display its Duall brand of corrosion-resistant en...
The new X-Strata980 X-ray fluorescence (XRF) instrument combines a high-power X-ray tube a...
