Liquid coatings are the highest volume finish type for OEMs and product finishers. Industrial paint application methods include methods like spray painting, dip coating and flow coating.
Curing Oven Basics
Liquid Coating: Essential Reading
Conveyors and Paint Systems
When to Introduce Automation Into Your Finishing System
Looking to increase productivity for your liquid coating operation? John Owed of Carlisle Fluid Technologies provides examples of how automation can help improve quality and efficiency for paint spray equipment.
How to Avoid Mud Cracking
Pretreatment for Painting
FAQ: Liquid Coating
What is liquid coating?
There are four basic ingredient classes found in all liquid coatings: binders, pigments, carriers and additives. In combination, these components create a liquid technology that dries to a film, providing protection and aesthetics. Each of these four components is integral to the coating composition.
What liquid coating is best for my operation?
An understanding of the composition and curing process of coatings provides insight for making a coating selection, helping finishers match the product to their performance, regulation and application requirements. The first decision in coating selection is often about the general type of technology preferred: solvent-borne, high-solids and waterborne.
https://www.pfonline.com/articles/choosing-the-right-liquid-coating-application
What is the best way to adjust viscosity in my paint?
Most coaters don’t think about the fact that adding solvent to reduce the viscosity of their coating is fundamentally changing the formulation of their paint.
Instead, we might try:
- Create a staging area to get the paint to the right temperature before we bring it to the line
- Develop summer/winter blends
- Install paint heaters
https://www.pfonline.com/articles/adjusting-viscosity-in-liquid-coatings
How can I minimize leakage during coating?
Here are some recommendations for avoiding plug loss, leakage and rework.
- Use the correct plug size
- Use the correct plug type
- Pay attention to the plug’s lifespan
- Use custom solutions
https://www.pfonline.com/articles/how-to-minimize-plug-loss-and-leakage-during-coating
Liquid Coating Suppliers
Narrow by Liquid Coating Category
- Waxes
- Viscosity Control Systems, Automatic
- Used Equipment
- Testing Service, Accelerated Weathering
- Thermometers, Pyrometers
- Thinners, Lacquer and/or Paint
- Testing Laboratories, Independent, Paint Finishing
- Testing Equipment, Thickness of Coating
- Testing Equipment, Thermal Cycling
- Testing Equipment, Slip & Friction
- Testing Equipment, Salt Spray
- Testing Equipment, Rectifier Ripple
- Testing Equipment, Paint Film Flexibility
- Testing Equipment, Paint Film Discontinuity
- Testing Equipment, Impact Resistance
- Testing Equipment, High-Voltage Electrostatic
- Testing Equipment, Gloss
- Testing Equipment, Color
- Testing Equipment, Electrochemical Corrosion
- Temperature Indicators
- Temperature Recorders
- Testing Equipment, Abrasion Resistance
- Testing Equipment, Adhesion
- Testing Equipment, Air-Motion
- Testing Equipment, Accelerated Weathering
- Software for Finishing
- Solar-Collector Coatings
- Spray Booth Cleaning Materials
- Spray Booth Coatings
- Spray Booth Lighting Fixtures
- Spray Booths, Paint & Powder Coating
- Spray Metallizing (Silver Spray) Supplies
- Spray-Gun Controls, Memory
- Spray-Gun Movers, Paint or Powder Coating
- Stop-Off Coatings, Waxes
- Tanks, Chemical Shipping
- Tape, Masking for Plating & Painting
- Spectrophotometers
- Shop Management Software & Systems
- Screen-Printing Equipment & Supplies
- Safety Equipment & Materials, Personal
- Robots, Painting & Powder Coating
- Robot Applicator Cleaner
- Rheostats & Switches
- Resins, Paint & Powder Coating
- Racks, Plating, Painting & Anodizing
- Racking/Unracking Machines
- Protective Films
- Rack Trucks
- Pipe-Line Strainers
- Plastisol Coating Materials
- Power Supplies for Electrostatic Processes
- Programmable Controllers
- Pearlescent Finishes
- Part Recognition
- Pigments, Metallic
- Pigments, Pearlescent
- Pipe & Fittings, Chemical Resistant
- Paint Training Equipment
- Painting Equipment, Personnel Carriers
- Painting Testing Equipment
- Panels, Paint & Plating Testing
- Masking Resins, UV Curable
- Masking, Customized
- Metalizing Sprays & Conductive Paints
- Noise-Control Enclosures, Devices
- Ovens, Convection
- Ovens, Infrared
- Ovens, High-Velocity
- Oven-Temperature Monitors/Curing Analyzers
- Infrared Heaters, Gas
- Inks, Metal Color-Coding
- Inks, Metal Decorating
- Lamps, Color Matching
- Magnets, Tank
- Hoists, Traveling: Automatically Controlled
- Hoists, Traveling: Manually Controlled
- Hoods, Masks & Breathing Systems
- Hoses, Air or Liquid
- Humidity Cabinets
- Flock-Finishing Equipment
- Flooring, Chemical-Resistant
- Fluxes, Tinning & Soldering
- Furnaces, Porcelain Enameling
- Gloves, Work
- Environmental Test Chambers
- Equipment Engineering & Installation Services
- Finishing Systems, Paint, Porcelain Enamel, Powder, Conveyorized
- Flame Spray-Coating Materials, Metal
- Flame Spray-Coating Materials, Plastic
- Drum Pumps
- Drum Warmers
- Drum-Handling Equipment, Accessories
- Electrolytic Lacquer
- Conveyors, Overhead Traveling Hoist
- Current Controls
- Conveyors, Wicket
- Current-Density Meters
- Drum Liners, Rubber, Plastic
- Conveyors, Inverted Power-and-Free
- Conveyors, Magnetic Belt
- Conveyors, Overhead Chain
- Conveyors, Overhead Power-and-Free
- Conveyor Lubricators
- Conveyors, Belt
- Conveyors, Chain-on-Edge Spindle-type
- Conveyors, Flat Pallet
- Conveyor Belts
- Conveyor Cleaning Equipment
- Conveyor Hangers, Rotating
- Conveyor Loading/Unloading Equipment, Automatic
- Controls, Burner
- Controls, Color
- Controls, Fluid Pressure
- Controls, Temperature
- Coatings, Electrocoatings
- Computer Control Systems for Finishing Processes
- Computer Software for Finishers
- Consultants, Independent, Organic Finishing
- Controls, Air Pressure
- Chemical Coatings
- Chillers
- Clothing for Paint Finishers
- Coatings, Ceramic, Refractory
- Coatings, Conformal
- Burners, Gas & Oil (Combination)
- Burners, Gas
- Burners, Oil
- Air-Sampling Equipment (In-Plant Environment)
- Air Make-Up Systems
- Analytical Equipment, Atomic Absorption, Spectrophotometric
- Analytical Equipment, Photometric
- Analytical Equipment, X-ray Fluorescence
- Associations, Tradeshows & Professional Groups
- Blowers, Air (for Push-Pull Ventilation)
