| 3 MINUTE READ
Post-Cleaning Corrosion Prevention
Appears in Print as: 'Post-Cleaning Protection'
Cleaning, passivation and corrosion protection are separate activities with distinct functions.
Facebook Share Icon LinkedIn Share Icon Twitter Share Icon Share by EMail icon Print Icon
In an industry in which competition among shops can be fierce, it’s critical to produce parts that are high quality and will stay that way for as long as possible. However, there are some obstacles that stand in the way of longevity, and corrosion is one of them.
Corrosion is the process by which metal surfaces are modified to form an oxidation product such as rust. To understand how corrosion works, consider the “corrosion square.” The parts of the corrosion square consist of an anodic area that supplies electrons, a cathodic area that consumes electrons, a conducting path between the two, and oxygen or an oxidizing chemical. To forestall corrosion, remove at least one component of the square.
Surface preparation, notably critical cleaning, must be understood and managed properly. Otherwise, the corrosion square slips back together and corrosion happens. One key to success is understanding that cleaning, passivation and corrosion protection are separate activities with distinct functions. Cleaning is removing soil or unwanted matter, without damaging the surface. Passivation, typically surface treatment with an acid, is a modification that leaves the surface less susceptible to corrosion. The notion that passivation can replace cleaning is not true. If the soils are polar, as is the case with salts, then passivation may be enough.
However, if metalworking fluids are used, usually non-polar, organic compounds are present. Acid treatment won’t remove most surface soils that accumulate during metal forming or fabrication. In fact, cleaning with water alone and then passivating is an invitation to corrosion. If the surface is not clean enough, passivation will not be consistent. There will likely be poor coating adhesion, leading to rejoining of the conductive portion to the corrosion square.
To effectively remove most soils, aqueous cleaning processes use basic (high-pH) or sometimes near-neutral cleaning agents. Solvent cleaning is sometimes preferred, on the grounds that aqueous processes leave a part “too clean.” This is because, while cleaning is an essential part of surface preparation, the soil, notably the metalworking fluid, acts as a non-conductive coating. The more effective the soil removal, the higher the potential for corrosion.
It is becoming more difficult to clean products, in part because metalworking fluids have evolved and leave more residue. In the past, manufacturers used “vanishing oils,” which left some residue on the part that served to protect the product from corrosion. The downside was that the oils evaporated into the air, resulting in pollution. To meet environmental mandates, metalworking fluids were reformulated to be less evaporative, which means they leave more complex residues on parts. These residues can interfere with subsequent assembly, coating and finishing operations, and must be removed using aggressive cleaning, resulting in a surface that is susceptible to corrosion.
One solution is to clean and then forestall corrosion using a corrosion inhibitor that reduces conduction, although any corrosion inhibitor will add a contaminant to the surface. The right corrosion inhibitor depends on the customer. In an era of increased cleaning costs and diverse customer requirements, those who fabricate, stamp or machine metal parts may, out of necessity, avoid making a decision about the correct cleaning process or the optimal corrosion inhibitor. The machinist may not do any cleaning and/or may supply the product packed in oil. In this case, cleaning processes may require higher temperatures, stronger physical forces, and longer cleaning and rinsing times than normal. More aggressive cleaning can lead to corrosion susceptibility.
For complex supply chains, customizing corrosion protection for a range of customers may require finesse. But, for the captive or dedicated machine shop, there is a simple, radical solution: communicate and coordinate.
Barbara and Ed Kanegsberg are industrial cleaning consultants with BFK Solutions, and industry leaders in critical/precision and industrial product cleaning. For questions or to receive their newsletter, call 310-459-3614 or email info@bfksolutions.com.
Related Topics
RELATED CONTENT
