Therma-Tron-X Powder Solutions
How to Protect Steel Parts From Rust Before Powder Coating
Choosing the wrong pretreatment can cost you adhesion and corrosion resistance. Learn which cleaners, conversion coatings and primers work best for your steel type.
parts to be cleaned, descaled
Source | Getty Images
Q: We are just learning about the powder coating process and are preparing to invest in a new powder coating system. We have been told that we must get the part clean before powder coating and are exploring our options. We are also looking at chemical treatments to provide better adhesion and rust protection. All of our parts are fabricated of mild steel from 16 gauge to ¼-inch plate. Are you aware of any uncomplicated pretreatment options that will work with powder coating and help to limit rust on steel surfaces with a lot of welds and complex shapes?
A: A good alkaline cleaner is usually a good place to start with cold rolled steel (CRS) that is relatively clean in the raw form. Your lighter gauges are a good fit for chemical treatment. It does a good job of breaking down organic rust inhibitors and similar soils.
Once a steel surface has been cleaned, it is desirable to add a conversion coating to protect from oxidation and to enhance bonding. Iron phosphate works well with powder but has modest corrosion resistance if the coating film gets scratched or damaged in some way. Zirconium oxide products can also enhance bonding and provide somewhat better corrosion resistance on different metals; some of the zirconium oxide products contain other metals such as copper or titanium and are good corrosion inhibitors. Zinc phosphate has very good corrosion resistance but it also requires waste treatment and would not be considered simple or environmentally desirable. Zinc will also require waste treatment where iron phosphate or zirconium may not need treatment in some locations.
When you get into the heavier plate steel and do welding using hot rolled steel (HRS), you should consider an abrasive step to remove inorganic soils such as rust and scale. If you cut steel with a laser cutter, you will likely have to blast or grind to take the scale off the cut edge. Again, lower gauges using the right gas for the laser operation may not need abrasion, but heavier steel plate likely will.
One of the best options for corrosion resistance is the use of a powder primer, especially for products that will be used outdoors. Thoroughly clean the surface by chemical or mechanical cleaning before adding the primer. If you use a chemical cleaner, you should also use a conversion coating to render the surface nonreactive. The powder primer can contain zinc or not. The zinc-rich primer works very well if the surface is roughened by blasting. It is less effective if the surface is not blasted because the zinc will not develop the kind of cathodic contact needed to provide the sacrificial barrier as intended. With or without zinc, the powder primer will provide exceptional resistance to moisture penetration and a thicker film with better edge coverage. The primer does a great job of stopping the spread of rust.
If you are doing indoor steel products of light gauge, an alkaline cleaner with iron phosphate or zirconium will work fine. If you have to go outside, you should consider an enhanced zirconium, zinc phosphate or a powder primer. If you have a lot of inorganic soils, such as rust or mill scale, you should abrade the surface.
About the Author
Rodger Talbert
Rodger has more than 30 years of experience in the powder coating industry.
RTT Finishing Solutions
Sames coating, bonding & sealing solutions
thermoset powder coatings
OptiFlex® Pro Manual & automatic powder guns
NASF Foundation Training & Education
applied surface technology
PRETREATMENT CHEMICAL APPLICATION SYSTEMS
basics
How to Address Declining Powder Coating Coverage Over Time
Fine particles from reclaim could be to blame for powder coating problems that emerge over time. Avoid problems by keeping hooks clean, maintaining guns and using reclaim powder quickly to avoid accumulation of fines.
Powder Coating
Tips for Discovering the Best Powder Coating Equipment
From test lab visits to comparing gun output and edge coverage, this short guide from Rodger Talbert explains how to evaluate powder coating systems that deliver performance and long-term value.
Electroplating
Practical Solutions for Pretreatment Challenges in Electroplating
Strengthening pretreatment is an essential step in ensuring the long-term performance, durability and finishing quality of an electroplating operation.
Top Shops
PF 2026 Top Shops Benchmarking Survey is Live
Benchmark, optimize, shine — join hundreds of  participating finishers for actionable industry insights. The survey will remain open through April 10, 2026.
automotive
How Dust-on-Dust Application Is Redefining Coating Systems
Dust-on-dust powder coatings are a strategic coating solution for manufacturers looking to scale production while meeting high performance specifications.
regulation
Reframing the Cost of Corrosion: What it Means for Coating Choices
A survey of 1,000 manufacturers reveals that North America is leading in advanced coating solutions while also weighing the true costs, risks and rewards of corrosion protection.
Powder Coating
Funky Finishes Explore the World of Unique Powder Coatings
Special effect coatings like metallics, textures, and functional and decorative finishes with visual and aesthetic focuses are quickly emerging and evolving.
