liquid coating solutions
Doing More with Less: Why Efficiency and Durability Are Redefining Sustainability in Surface Finishing
The conversation around sustainability is evolving — and in surface finishing, how efficiently a coating is applied and how long it lasts matter more than ever.
Jerimy Erickson, Global Director of Product Management, Sherwin-Williams General Industrial
spray gun
Source | Getty Images
Q: Sustainability in coatings has traditionally centered on emissions and materials content. Why is the conversation now shifting toward efficiency and durability?
A: Sustainability in manufacturing is often driven by regulatory compliance — volatile organic compound (VOC) limits, reporting requirements and material disclosures. But today, customers, brands and supply chain partners are increasingly focused on life cycle impact — not only what goes into a product, but the energy it takes to create that product and how long its usable life will be.
In industrial finishing, efficiency and durability play critical roles in overall sustainability. A coating that takes fewer resources to apply and performs well over time reduces short-term consumption and longer-term maintenance, meaning less raw materials, energy, labor and transport.
The shift in sustainable thinking
Sustainability is no longer a differentiator reserved for a select group of manufacturers — it’s becoming a baseline expectation. Research from Bain & Co. shows that half of corporate buyers are already increasing business with suppliers that demonstrate stronger sustainability performance, and nearly 70% plan to do even more over the next three years.
For manufacturers, this means sustainability is no longer assessed solely by what a product contains, but also by the resources used to create that product and how it performs over time.
So, what role do coatings play in this new way of thinking? Let’s put regulatory compliance aside for a moment. Today’s manufacturers are constantly challenged to do more with less. Operational efficiency has become a new measure of sustainability, and one that contributes to profits as well as reputation.
Modern coating technologies can help manufacturers reduce environmental impact by improving process efficiency, including:
  • Low-, fast- and ambient-cure chemistries shorten or remove bake cycles.
  • Single-cure formulas streamline processes and reduce oven demands.
  • Lower oven temperatures reduce energy consumption.
  • Shorter dwell times increase line speed and throughput.
  • Improved transfer efficiency minimizes material waste.
  • Less hazardous formulations help reduce exposure risks.
If efficiency reduces impact at the start of the process, durability multiplies those benefits over time. A durable coating helps:
  • Extend the service life of finished products.
  • Reduce material and energy consumption associated with maintenance.
  • Minimize waste and disposal of unprotected products.
  • Lower the frequency of recoating and rework.
Industrial coatings have long supported sustainability by protecting substrates from corrosion, wear and environmental exposure. The longer a coating performs as intended, the fewer resources are required over the product’s lifespan, making durability one of the most effective sustainability levers available in surface finishing.
Efficiency and durability in supply chain sustainability
For most companies, the largest share of emissions comes from their value chain, particularly upstream activities like suppliers, materials, energy use and transportation. Under the Greenhouse Gas Protocol’s Scope 3 standard, these indirect emissions can make up more than 90% of a company’s total footprint, depending on the industry and business model.
Because Scope 3 emissions occur outside a company’s direct control, collaboration is essential. Manufacturers are increasingly evaluating suppliers based on how their products contribute to energy efficiency, long-term performance, reduced waste and life cycle performance.
In industrial manufacturing, durable coatings can support these goals by keeping products in service longer and reducing the need for replacement materials — an important step toward more sustainable, resilient supply chains.
A smarter path forward
To remain competitive in an increasingly sustainability-driven market, manufacturers must look beyond surface-level metrics and consider full life cycle impact.
By prioritizing coatings that combine efficient application with long-lasting performance, manufacturers can reduce environmental impact over time, support customer sustainability goals, improve operational efficiency and drive responsible growth across supply chains.
For decades, industrial coatings have helped extend product life. By continuing to innovate around efficiency and durability, the industry is well positioned to help manufacturers meet today’s expectations and tomorrow’s challenges.
About the Author
Jerimy Erickson, global director of product management, Sherwin-Williams General Industrial
Jerimy Erickson
Jerimy Ericson is global director of product management for Sherwin-Williams General Industrial. Contact: industrial.sherwin-williams.com
Binks IntelliFlow electronic mixing systems
NASF Membership
Parts Cleaning Conference 2026
automated finishing systems
CONTRAX
Top Shops Conference 2026
Electroplating
The Future of Hard Chrome: Pioneering Innovations for Sustainable Solutions
Although useful, chromic acid and other compounds that contain hexavalent chromium ions are highly toxic and carcinogenic. However, one company has developed an alternative for the hard chrome process that achieves thick, conformal coatings with wear and fatigue resistance comparable or superior to hexavalent chromium-based systems.
Anodizing
Surface Treatment Breakthroughs for Recycled, New Aluminum Alloys
Recycled alloys and surface treatments like anodizing are driving durability and eco-friendly innovation in modern applications.
regulation
Reframing the Cost of Corrosion: What it Means for Coating Choices
A survey of 1,000 manufacturers reveals that North America is leading in advanced coating solutions while also weighing the true costs, risks and rewards of corrosion protection.
sustainability
Functionalizing Surfaces for Sustainability
Riblets reduce drag, fuel consumption, CO2 emissions and noise while boosting power output, flow rates, speed and efficiency.
Electrocoating
Smart Coatings for Extreme Environments: Innovations in Aerospace and Defense
Smart coating developments are enabling engineers to reduce wear and extend mission life in extreme environments.
Liquid Coating
Selecting a Spray Applicator for Liquid Coatings
Struggling to pick the perfect spray gun for your finishing ops? Explore spray applicator types, advantages and applications for optimal transfer efficiency and finish quality.
Powder Coating
Funky Finishes Explore the World of Unique Powder Coatings
Special effect coatings like metallics, textures, and functional and decorative finishes with visual and aesthetic focuses are quickly emerging and evolving.
Liquid coating solutions
