liquid coating solutions
Protecting Grounding Areas: A Critical Step in Coating and Plating
Learn best practices for precision masking to protect electrical grounding surfaces in electrocoating, plating and anodizing, ensuring conductivity and functionality.
Brian Asik, SVP, Custom Fabricating & Supplies
Silicone tapered flange plugs
Silicone tapered flange plugs are used to mask a grounding area and can be used in threaded or non-threaded blind or through holes. Temperature rating: 600°F (315°C). Source (All Images) | Custom Fabricating & Supplies
In finishing operations like electrocoating (ecoat), plating, powder coating and anodizing, certain surfaces must remain uncoated to support future electrical grounding or contact once the part is in service. These areas — often threads, pads, studs or machined faces — need to be protected so that they remain bare and functional.
Precision masking ensures that these contact surfaces stay clean, functional and dimensionally within spec — even after aggressive coating or chemical environments. Best practices for protecting these important contact points are described below.
Know the requirements
From the start, it’s helpful to engage early with design and manufacturing teams so that masking needs are built into the part design. Identify key contact points, confirm post-coating tolerances and ensure the geometry supports secure masking without adhesive issues. Early collaboration reduces rework, scrap and helps determine the best masking approach.
It is important to select masking materials that align with the process. High-performance masking materials can withstand chemical baths, high temperatures and electrical current. The following are recommended:
  • Silicone or EPDM caps and plugs for harsh chemical and temperature exposure.
  • High-temperature polyester, polyimide and glass cloth tapes for ecoat, powder coating and anodizing.
  • Custom die-cut or molded masks when geometry or consistency demands higher precision.
Material choice must also prevent leaching, adhesive transfer or degradation that could interfere with conductivity.
Silicone step plugs
Silicone step plugs are used to mask lead in threads and grounding areas. A flange aids in placement and removal. Temperature rating: 600°F (315°C).
Getting the right fit
It is also important to ensure a firm, repeatable fit on critical grounding surfaces. For grounding areas, even a thin film of coating or residue can compromise performance. Best practices include:
  • Using adhesive material that offers clean removal, so that no residue is left behind to interfere with electrical conductivity.
  • Using masking that can offer a seal, such as caps, plugs or boots, to keep contact surfaces fully protected.
  • Verifing the mask fits securely enough to avoid blow-by but not so tight that it distorts the part or is difficult to remove after coating.
A reliable seal is essential to preserve bare metal for post-process electrical performance.
Make sure to define clear mask lines and tolerances. Instances of coating creep, edge build and inconsistent mask lines can affect not only surface fit but also grounding area conductivity. Things to consider in part design include establishing acceptable and reasonable mask-line tolerances (e.g., ±0.5 millimeter), guidelines for chamfered or radius edges where masking is easier to control and criteria for inspecting and approving masking boundaries.
Well-defined expectations between finishing vendors and manufacturers reduce ambiguity and rework, helping to support a positive outcome.
Green polyester masking films
Green polyester films can be custom die cut to cover grounding areas; this material removes cleanly even after long bake cycles. Temperature rating: 400°F (204°C).
Always consider custom or engineered masking solutions. When standard plugs, caps and tapes cannot meet the required precision — especially on grounding faces, curved surfaces or complex geometries — engineered masking solutions can help. This may include:
  • Custom-molded silicone caps, plugs and boots for multi-feature protection.
  • Precision die-cut tapes for tight contact features.
  • Locking or threaded masking components for secure positioning.
Engineered solutions may take some time to develop, but in the long run will reduce labor time and improve consistency for high-volume production.
Validation and documentation
Validation of conductivity post-coating is a critical step and masking effectiveness should be confirmed through inspection and electrical testing. Testing and validation methods should include the following:
  • Visual checks for coating bleed, adhesive residue or pinholes.
  • Measurement of the grounding surface dimensions after coating.
  • Electrical continuity or resistance testing to ensure reliable contact.
Ultimately, post-process validation can help to ensure the grounding function is not compromised by process variation.
It is also important to document and standardize masking procedures. Repeatability depends on clear, accessible documentation. Best practices include:
  • Visual work instructions showing mask placement and orientation.
  • Lot-to-lot tracking and sampling of mask types and material batches.
  • Defined intervals for mask replacement to prevent wear-induced failures, and to keep up with product development.
Standardization enhances quality control, especially when multiple operators or shifts are involved.
Repeatability, durability and reliability
Precision masking plays a critical role in protecting electrical grounding surfaces during anodizing, electrocoating, plating and other coating processes. The right materials, along with well-defined processes and early collaboration, will help keep contact surfaces clean, conductive and ready for final assembly.
Part recommendations for masking the grounding area of your part include silicone washer plugs, washer pull plugs, step plugs and tapered flange plugs; hanging threaded plugs; and custom-engineered solutions that are tailored to the geometry of the part.
As finishing requirements become increasingly demanding, manufacturers benefit from engineered masking solutions that deliver repeatability, durability and confidence in performance.
About the Author
Brian Asik headshot
Brian Asik
Brian is senior vice president of Custom Fabricating & Supplies. He is responsible for directing sales, product development and manufacturing operations. Contact: customfabricate.com.
Binks IntelliFlow electronic mixing systems
Industrial adhesive tapes, silicone caps and plugs, molded parts, gaskets and seals, masking solutions, masking products
FABTECH 2026
Parts Cleaning Conference 2026
applied surface technology
NASF Membership
masking
Top Shop Builds Original Systems for Coating Medical Devices
Engineers at Surgical Coatings in Colorado have been ingeniously developing their own equipment, automation, processes and software since this powder coater’s inception in 1995.
masking
Balancing Cost, Precision and Speed in Label Application for Manufacturers
Modern paint masking solutions offer reliability and process simplicity.
surfin
Discuss Masking Challenges in Real Time With Caplugs Engineers
SUR/FIN 2026: Take advantage of Caplugs’ more than 76 years of product protection, masking, finishing and custom molding experience.
Electrocoating
From Zero to Full: The Day That Nearly “Finished” a Finishing Shop
What began as doomsday for this Michigan finisher turned out to be a victory when the shop went from no ecoat business to full capacity. After that day and within two weeks, management onboarded 72 employees to keep up with its business.
Parts Cleaning
Practical Solutions for Pretreatment Challenges in Electroplating
Strengthening pretreatment is an essential step in ensuring the long-term performance, durability and finishing quality of an electroplating operation.
Ask The Expert
Do You Have Good Ground?
John Cole, president of Parker Ionics, discusses his favorite subject: why having a good ground is so important for your powder coating process.
Sponsored
Surface Protection for Blasting, Flame Spray and Demanding Applications
During harsh industrial processes like media blasting and thermal coating, surface protection tapes can provide durable, reliable barriers for masking solutions that perform under pressure.
Liquid coating solutions
